DCTOM AND OTHERS
JDB
10-01-2004 06:25:50
Chain that drives the hydraulic pump on my DC seems awfully loose. How much slack should it have in it? Also, Should the brass bushings in the pump drive sprocket float around back and forth or should they be a tight fit?
Bruce Nelson
10-02-2004 06:24:37
 Re: DCTOM AND OTHERS in reply to JDB, 10-01-2004 06:25:50
I just put a new chain in my DC. The old one would move about 3/4" side to side and the new chain moves about 1/2" side to side. The chain costs less than $5.00. Another $1.95 for a connecting link. The bushings should be tight in the lower sprocket/shaft. The shaft will slide maybe an inch fore and aft in the tractor with the pump removed. With the punp installed, the lower shaft will still wiggle some, maybe up to 1/8". e-mail me direct if I can help more. Bruce
DCTOM
10-01-2004 17:25:42
JDB, THE CHAIN CAN RUN LIKE IT IS TOO LOSE, ONLY REMEDY WOULD TO BE PUT A NEW ONE IN, MAYBE YOURS HAS STRETCHED SOME,. THE BUSHINGS MAY BE WORE A LITTLE WHICH COULD MAKE THE CHAIN LOSE DCTOM
JDB
10-04-2004 10:19:07
 Re: DCTOM AND OTHERS in reply to DCTOM, 10-01-2004 17:25:42
THANKS GUYS
