Question from a Farmall guy-Case SC
will-shooter
09-29-2004 20:34:19
Just wondering if anyone can give me any information about a Case SC-HP, what it was rated for-plows, etc... hydraulics... PTO... general info. I'm currently considering making a purchase.
Thanks in advance..
Will
Will-Shooter
09-30-2004 16:38:09
 Re: Question from a Farmall guy-Case SC in reply to will-shooter, 09-29-2004 20:34:19
Thanks guys... now Ill I have to decide is if I want it. Never have owned anything orange before...
Will
C. Amick
09-30-2004 09:48:09
Should pull 2-14's in 2nd. gear,even in the lower 22 drawbar horsepower (3-1/2" piston)version. Case later went to 3-5/8" pistons and a higher compression head. Aftermarket button top pistons (3-11/16") were available that put the horsepower over 30. The tractor should be the equivalent of a Farmall H, although my neighbor's Farmall H wouldn't pull the plows that the SC pulls. His tractor may just needed a tune up . :)
Glenn FitzGerald
09-30-2004 09:27:23
pre '53: 19.4 drawbar, 22 belt '53 and '54: drawbar 28, belt 31.71. Glenn F.
todd hamilton
09-30-2004 05:29:42
Depends on year as SCs were made from '41 to '53 or '54. Most HP will fall into the 18 - 22 range, we pulled a 2 18" with Dad's '41 SC (gas with LP head modification) when I was a kid. 540 PTO standard on all SCs (I think), optional on S (standard), SI (industrial), SO (orchard). Most production prior to WW II had mechanical lifts with no hydraulics. Hydraulics and/or Eagle hitch (Case 3-point) mostly available on the late 40s - early 50s production. My Dad had an SC, Grandad had a Farmall H, Uncle had Farmall C and Farmall M.
