Rear Rim Removal On L
ScottRen
09-29-2004 16:22:37
Anybody have ideas on how to remove a rear wheel from a Case L? I have a large puller on the wheel and cannot get the hub to pop from the tapered axle. I drove around with the puller on the hub without results. Any thoughts?
Casenut
09-30-2004 16:11:18
 Re: Rear Rim Removal On L in reply to ScottRen, 09-29-2004 16:22:37
I have had very good luck wrapping a chain around the spokes and placing a 10 ton bottle jack between the chain and the axle (piston against axle) everyone I have done comes off very easily (let me know if you have questions)
ScottRen
09-30-2004 18:08:33
 Re: Rear Rim Removal On L in reply to Casenut, 09-30-2004 16:11:18
I built a puller out of 3/4 inch steel plate. I have so much pressure on the plate that I am bending it. That hub will not budge! I even hit it with a 4 lb hammer and nothing will give. I drove the tractor in several directions thinking it would pop loose. Nothing. I have NEVER seen anything as stubborn as this.
RobertTX
09-30-2004 05:46:31
I built a puller like Steve described and it did not work. The best results I have had removing the wheels is hitting the end of the axle with a 10 lb hammer. Putting a hydraulic jack behind the wheel pushing out helps sometimes. Block the tractor so the axle you are working on is pointing slightly down, wheel off the ground, and cover the threads with a few layers of duct tape. If it is going to come off, it will take less than 10 blows with the hammer. I have had better success with the big cast hubs on the LAs than I have with the steel wheels on the Ls and LAs. I have been able to get all the LA hubs off, only 50% of the steel wheels. Driving around with the axle nut loose may be a good shot, all the ones I have been taking off were on non runners.
Steve (DE)
09-29-2004 20:11:13
I haven't done it myself, but it is in my future. Case put out a booklet in the 1930's about using their special tools. There they had a steel strip (maybe 1" x 2" cross section and a foot or more long). Towards each end of it there was a 3/4" diameter hole. You put a 3/4" bolt through the hole, and threaded it into holes in the center, hub portion, of the wheel. The metal strip rested across the end of the axle. Then you "simply" screwed the bolts down, and the steel strip pressed across the end of the axle and popped off the wheel. Does it work? Got me.
Alternative B - get in touch with Joe Peeper who I know just took a pair of rear wheels off an L.
