case 1150 final drive removal
Walter Franke
09-29-2004 07:32:44
I need to replace the right side final drive on a case 1150 track loder. Can anyone tell me the correct way to remove the old final drive.
george md
09-29-2004 16:22:38
 Re: case 1150 final drive removal in reply to Walter Franke, 09-29-2004 07:32:44
Walter,
It is not a real hard job , I made an offset bracket that makes life much easier . Send me an email and I'll send you a picture
and a how to .
george
Dan in Ohio
10-15-2005 14:33:18
 Re: case 1150 final drive removal in reply to george md, 09-29-2004 16:22:38
Got a question, when the final drive is re-assembled and you are setting shims on output, how hard should it be to turn the input shaft when the shims are properly set.? Appreciate any feedback. Wouldn't mind seeing that offset bracket. Thanks
