looking at a Case 430: pros/cons/values?
Paul Z
09-29-2004 07:06:04
third party image
Looking at a Case 430, the engine has been recently overhauled, has nearly new rear rubber, runs well, needs cosmetics.
What is the good and bad about these tractors, weak points, reliability, parts availability, etc. What kind of money are these things bringing these days?
thanks in advance!
S. Jewell
10-01-2004 15:25:31
 Re: looking at a Case 430: pros/cons/values? in reply to Paul Z, 09-29-2004 07:06:04
Check the wish bone and the casting where the wish bone attaches to the tractor (under the clutch)on the wide front prone to cracking. Also check the oil levels in the trans and triple range look for hydraulic fluid in the transmission, if oil level in transmission is over full and hydraulic level in triple range is low(like doesn�t read on dipstick) you may have seal problems between the transmissions, if left unfixed it may cause problems with oil leaking i.e., brake linings, pto seals, rear axle seals and blowing out the speedometer cable hole on the top of the tranny case during road transport. Check the rear tire size, 36's are hard to find tires and rims. I bought a 630 for $1700. this summer and I wouldn�t sell it for $5000. Great tractor!!!!
TractorChuck
09-30-2004 15:21:29
With a fresh overhaul and new rubber, she'll work hard for another 40 years.Regardless of price,if it says Case on it,it's worth every penny.
Ray in WA
09-30-2004 07:02:06
I bought one new in 1968 w/Loader for $4800.00. You can not find a used one here now for any price. Ray in WA
mike's600
09-29-2004 16:11:06
I just got one with a 188 dsl., sat for four years, put a battery jump box on it , three turns, and runs perfect.Great little tractor, planning on selling.
Gene Dotson
09-29-2004 14:21:52
One thing to watch for is broken lower front engine mount where the front casting bolts on. Some tractors used with loaders have broken these. Some have been welded and a side rail made between the front casting and bell housine. Not a bad idea if you plan to put a loader on it... Gene
Joe (Wa)
09-29-2004 16:03:32
 Re: looking at a Case 430: pros/cons/values? in reply to Gene Dotson, 09-29-2004 14:21:52
The implement side rails were an option on the 300B & 400b series. Reinforcement rails can be readily fabricated and definitely a good idea.
John H-WI
09-29-2004 13:56:33
Darn good tractor. By the looks of this one doesn't need too much before paint job. John Davis has grill screens 937-596-6295. Price depends on your area. Would say $3000 plus or minus.
JerryW
09-29-2004 08:41:03
As good a little tractor as ever manufactured. No cons in my humble opinion and I have no idea of value.
Jerry
C. Amick
09-29-2004 13:39:19
 Re: looking at a Case 430: pros/cons/values? in reply to JerryW, 09-29-2004 08:41:03
I think most major mechanical parts are available from Case/IH, but they are expensive. Always heard it was a very good tractor. Value depends somewhat on location. With an engine rebuild and good tires, my guess is around $3,500.
