SC Rear Axel Seals
Glenn FitzGeral
09-28-2004 22:40:33
I have eliminated nearly every leak in the '54 SC. I plan on putting the head on possibly this weekend. While it's in the shop I'd kind of like to replace the rear axel seals. Then It'd be mechanically finished. I have figured all along, the rear cast iron wheels need to come off to replace the seals...? I was just thinking tonight, possibly the packings could simply be replaced w/o removing the wheels? I made a slight attempt to loosen up a couple of the outside wheel bolts on one side. It was more than the 3/4" drive socket and I could do. Looks like I'll be calling on the torch! Do they for sure have to come off? Thanks, Glenn F.
C. Amick
09-29-2004 05:56:11
 Re: SC Rear Axel Seals in reply to Glenn FitzGerald, 09-28-2004 22:40:33
I have a list of Case SC replacement seal numbers that someone sent me, if you need them email me.
John Saeli
09-29-2004 05:08:04
Hey Glenn: Yes, the wheels have to come off. No shortcuts. Are they weeping?
Glenn F.
09-29-2004 19:50:34
 Re: SC Rear Axel Seals in reply to John Saeli, 09-29-2004 05:08:04
You know...I need to watch them closer. I know if it is not sitting level it will leak on the low side. Oil level is not too high. Glenn F.
John Saeli
09-30-2004 04:55:27
 Re: SC Rear Axel Seals in reply to Glenn F., 09-29-2004 19:50:34
Hey Glenn: Change them.
todd hamilton
09-29-2004 18:16:21
If so, are they depressed???:^)
