SC Steering Worm Gear Worn
Glenn FitzGeral
09-28-2004 22:28:43
I took the top off the SC transmission tonight to check out the slight play in the steering. Wear in the worm gear is the culprit. Everything else is tight. I put it back together. Oh well...! Glenn F.
Larry Martin
09-29-2004 17:57:55
 Re: SC Steering Worm Gear Worn in reply to Glenn FitzGerald, 09-28-2004 22:28:43
Glen, did you remove the arm and rotate the shaft 180 degrees before putting the arm back on? This allows the worm to work on a new portion of the steering gear.
Glenn F.
09-29-2004 19:53:54
 Re: SC Steering Worm Gear Worn in reply to Larry Martin, 09-29-2004 17:57:55
Yes I did. Actually this only changes the surfaces on the big gear. The worm gear position cannot be changed. Glenn F.
