Min. rpm to lift weight of scrape blade ?
JB (TN)
09-28-2004 17:42:27
I have been working on hydraulics on 885. Found ball and retainer missing in hold valve. Replaced those and seems to work a little better in lifting. Blade will start to lift at 1300 rpm. Is this normal? If not I think this would leave the problem to be a bad pump relief valve, bad cylinder relief valve or worse case a bad pump. Lift holds good and lowers good. Thanks for any help.
