Plowing with Case VAC
Bill
08-16-1999 04:06:20
I recently bought a Case VAC with no attachments. I'm using it to help clear land and am curious if anyone has had successful experience plowing snow with one. What type of setup do you use? Thanks. Please email. - Bill
toolbox
08-18-1999 16:50:45
 Re: Plowing with Case VAC in reply to Bill, 08-16-1999 04:06:20
If you have the Eagle Hitch, then a standard 3 pt. blade works well. On VAC's with no Eagle Hitch, I've seen front blades that operate off the implement lift. I agree with C. Amick that tire chains and wheel weights are a good idea.
C. Amick
08-16-1999 10:06:52
To be successful in plowing snow with it you will need tire chains. My dad has an old Fergueson 3-point hitch rear blade he uses with his VAC. It does a pretty good job although it would perform even better with wheel weights or fluid in the tires.
