Case 580E Differential Lock
Rick Suttles
09-28-2004 11:11:35
My diff lock on my "84 backhoe doesn"t work - When I bought it used recently, the spring connecting the pedal to the lever on the trans. wasn"t connected, so I connected it. However, the lever won"t budge. Question 1 - is it possible that the lever is simply frozen from lack of use, or is there the possibility of internal damage. Question 2, if it is possibly frozen up, can I remove the cover and not expect a wall of fluid to come rushing out at me? And will you sell me your service manual when you get tired of it?
JimKS
09-29-2004 20:20:22
 Re: Case 580E Differential Lock in reply to Rick Suttles, 09-28-2004 11:11:35
That lever is probably frozen up from not being used. The differential lock is under that little cover that the lever sticks out of. You can remove that cover without draining the oil- that cover goes on the brake housing, and a 580 E has dry brakes. Chances are you can just free up the lever and it'll work... make sure the splined piece in there and the fork is ok.
