hydraulic layout case 195
les turner
09-27-2004 17:40:17
need help on piping from pump to the rest of the tractor.
les
Klyde
09-27-2004 17:50:16
 Re: hydraulic layout case 195 in reply to les turner, 09-27-2004 17:40:17
From the pump to the control valve, out of control valve to cooler, from cooler to transmission, out of transmission to pump. control valve director lines go to hydraulic motor on transmission.
les
09-28-2004 17:19:40
 Re: hydraulic layout case 195 in reply to Klyde, 09-27-2004 17:50:16
ok thanks,but if you have a tiller on it where does the oil come from for that...my pump oil goes to the tiller contol valve threw an adjustable flow control valve,then to the control valve to the transmission out from there to the lift for the tiller then to the cooler then back to the transmission and back to the pump..... something just dont seem right,if the tiller is working the tractor has very little movement forward and backwards
Klyde
09-28-2004 17:38:07
 Re: hydraulic layout case 195 in reply to les, 09-28-2004 17:19:40
The flow control vale is the only place it can be loosing flow. That has 3 lines on it, right? Could try a heavier weight of oil in the system. After this many years of eating transmission fillings that pump is bound to be quite worn.
les
09-29-2004 17:52:08
 Re: hydraulic layout case 195 in reply to Klyde, 09-28-2004 17:38:07
3 lines on each of the control valves and you could be right about the filings,do you think a pump is available for this tractor....
les
