Case 508E (Super E)
Dan Davis
09-27-2004 17:24:24
I have had a problem with my deisel backhoe. It will move forward and then reverse using the hydrostat shifter. Once it moves forward it will only go back. YOu shut it off and it will then go forward and back again. Spuratic reaction to the hydro shifting lever. It is not always the same situation and for some reason the gear shift would not go in. After moving a couple of wires below the shifter worked but the spuratic forward and backward movement still happened. What suggestions do you have that could cause this.
