 Well, it's been a while since I posted any pictures, but I've started working on the last piece of sheet metal, the grille. There were a few cracks, two holes, and two broken brackets. I did some MIG welding and then grinding, still a bit rough. It will need some finish disk work as well. I cooked the bottom portion of the part in my electrolysis tank, and you can clearly see how deep my tank is! The was after three hours at only 5 volts. Sure beats paint remover. I'll flip it over and do the other end this afternoon, then give it a spritz of phosphoric acid to keep from rusting until I can get back to it, hopefully next weekend. Then some medium body work, one last dip in the tank. then some epoxy primer, high build primer, finish sanding and any minor filling, then paint color, wet sanding, then clearcoat. I'll try and post more pictures along the way. Frank-in-Tallahassee 70D // 855 // VAC // IHC �Cub� [email protected]
