I Messed Up The Rear Axle Threads (Case L)
cheg
09-25-2004 19:29:59
Today I was taking off the axle nuts on a 1937 Case L. One castle nut was tight so we heated it and soaked it in penetrating oil. We used an impact wrench and the threads pulled out of shaft. Any ideas on what I should do? Does anybody know where I can find a replacement axle? Would it be better to have a machine shop re-cut the threads?
Thanks
Joe Peeper
09-26-2004 18:27:25
 Re: I Messed Up The Rear Axle Threads (Case L) in reply to cheg, 09-25-2004 19:29:59
I have an axle in a 1929 L tractor if that would help. Email me and we can talk about it.
Brian in Ohio
09-26-2004 08:12:26
I assume this means that you found a set of cutoffs for your L?
DKase
09-26-2004 06:11:02
Inside end, or outside end? If a thread file, or thread chaser would not clean them up good enough to use I would think about either building them up and cutting new threads, or cutting the next size smaller threads on the shaft. LOL DK
