DB 885 injection pump leak (shut off shaft)
JB (TN)
09-25-2004 14:23:26
The cav injection pump has started leaking from the pump shut off shaft. Is there an o-ring or seal that can be replaced? The cover the shaft runs through appears to be attached with two bolts about center of the cover, with a sealed wire connecting them. Tractor is year 74 and pump is CAV Mod. # 3233F000. I don't have a parts diagram to look at for this pump, is one available? Thanks in advance for any help.
