SC FLYWHEEL PULLY
BOB S
09-24-2004 21:05:24
Ihave a sc need to know to remove the pulley off the crank on the front of the engine thank you BOB
L.Lamp
09-25-2004 18:48:27
 Re: SC FLYWHEEL PULLY in reply to BOB S, 09-24-2004 21:05:24
The thing to do is to first drive out the self locking pin holding the pully on. They can be quite stubborn. My best success has been to drill into the pin about 3/16" with a 3/16" bit and use a punch that fits the hole you made and keep pounding till the pin comes out. You avoid mushrooming the pin doing it this way. Use a good grade of penetrating oil and attach a puller. They don't give up easy.
