DB 885 Hydraulic Lift Problem For Elmer
JB (TN)
09-24-2004 17:30:57
74 885 lift is slow with any heavy weight, new to forum. I started with the hold and by-pass valves after seeing some of Elmers posts. Someone had been in there before as the screws were buggered and I think I have found the problem or at least the first one. Whoever had the hold valve out either forgot to put the 1/8" ball and retainer back in or lost them and didn't replace (good mechanic). Both valve orfices and nylon screen were clean and valves were stick free and I'm hoping that this is the only problem. Ordered parts today. I'm not great at hydraulics but looking at the C-203 manual schematic I think this would allow the fluid to dump and provide very low lift pressure at the same time. Is there anything else that this condition could have damaged? Lift would lift normal with light boom pole.
