Case 1030
Kelly
09-24-2004 11:22:41
I am looking for a used engine for a case 1030 Comfort king. Along with the torque specs for the head bolt.
I have a case 1030 that has a cracked block and have had it welded. Does anyone have any information or advise as to whether or not this is going to work? I don"t want to put a bunch of money into it if it isn"t going to work.
JCMarleau
09-26-2004 19:20:32
 Re: Case 1030 in reply to Kelly, 09-24-2004 11:22:41
Where are you located cause i have a good 1030 block my e mail is [email protected]
Kelly
09-28-2004 17:16:46
 Re: Case 1030 in reply to JCMarleau, 09-26-2004 19:20:32
I am in Oregon. Will e Mail you. Thanks
Leland
09-26-2004 18:00:01
Kelly I just remembered a junk yard in cent ILL had a couple of 830 or 930s in his yard these may fit his name is Roger Eaton call 217-459-2767 his mom will give out his cell #
John Saeli
09-24-2004 17:53:19
Hey Kelly: No reason why the welded block won't work. Where was it cracked?
kelly
09-25-2004 08:20:27
 Re: Case 1030 in reply to John Saeli, 09-24-2004 17:53:19
It was cracked along the side but there are also some cracks on top between the pistons. The heads aren't cracked though so I am crossing my fingers.One of the pistons is broken and I am told that it will still run but I will lose some horsepower. do you know?
John Saeli
09-25-2004 19:16:33
 Re: Case 1030 in reply to kelly, 09-25-2004 08:20:27
Hey Kelly: I've seen some ugly external cracks that were fixed so you could never tell. The cracks between the cylenders are harmless cause the sleeve takes the beating, & the head gasket seals everything. The broken piston is junk. Can't imagine why anyone would tell you different.
