870 lights
brandon boone
09-23-2004 19:54:12
the lights havnen't worked in a long time on this tractor. the bulbs are ok. All i found was some wires that had come unplugged underneath teh right side of the tractor by the tire. i hooked them back up and still nothing. where do i look next
John Saeli
09-24-2004 17:56:14
 Re: 870 lights in reply to brandon boone, 09-23-2004 19:54:12
Hey Brandon: If memory serves me correctly, power is fed to a Circuit-breaker mounted on the switch. Power then goes out from the switch. If you are getting power to the switch, check out the switch. If power is going out, check the wiring. Look for corrosion. Good luck.
