Mag
Ed Rothwell
09-22-2004 18:26:11
Need help with a Bosch mag # MJA4B-112. How do I set the timing on the in side of the mag. I have set everything on c don't know how to set the gears. Thanks: ED
Glen in TX
09-23-2004 00:44:49
 Re: Mag in reply to Ed Rothwell, 09-22-2004 18:26:11
Ed, Your 112 should be a clockwise driven mag from back side. Turn the magnet gear with key pointing up. Then line up the "C" mark on the dist. rotor disc with the key way on magnet gear. Should be a indicator washer on there that has a hole in line with keyway. It slides on with the rotor in between the disc and gear. Then install the cam with C mark aligning with key also.
