case 900
bill m
09-22-2004 17:15:33
Can you use the 451 or 504 sleeve in is block.
CASE1979
09-24-2004 22:55:38
 Re: case 900 in reply to bill m, 09-22-2004 17:15:33
Sorry I wasnt specific enough with boring the block I thought that might be understood. I figured that you would know that scince the 504 pistons are a bigger dia. than the 377 sleeve sorry agian
DKase
09-24-2004 06:11:25
Sorry for the bad advice that you have received, but 504 sleeves will not fit in a 377 without boring the block. LOL DK
bill m
09-23-2004 14:15:01
where can you find 504 sleeve's.
CASE1979
09-24-2004 22:58:20
 Re: case 900 in reply to bill m, 09-23-2004 14:15:01
I have eleven used ones that are still good enough to use with the minnie mo pistons
case1979
09-23-2004 07:34:47
You can use the 504 sleeves in the block there 4&5/8 then just use the moline pistons there flattops and have enough meat on the top of the piston to machine what you need off and you can use a bushing in the rod to fit the m-m wristpin
