Need More Help
Joseph
09-22-2004 16:50:09
I need more help to fix my carb the throttle arm only move when the engine is off???? Please help!!!!
09-22-2004 17:30:13
 Re: Need More Help in reply to Joseph, 09-22-2004 16:50:09
IF THE THROTTLE ARM ON THE CARB MOVES FULL OPEN WITH ENGINE OFF BETTER CHECK THE GOVERNOR OR THE LINKAGE
Joseph
09-22-2004 20:34:26
 Re: Need More Help in reply to [email protected], 09-22-2004 17:30:13
How would I go about checking the governor and the likage? The linkage looks ok but I'm not sure?
THANKS!
Glenn F.
09-22-2004 20:55:58
 Re: Need More Help in reply to Joseph, 09-22-2004 20:34:26
Remove linkage from carburator. Push carb butterfly back till it hits the stop. Make sure governor arm is at zero. Adjust linkage to proper lemgth and re-attach.
