420B starter leaking ATF
Bill G
09-22-2004 10:47:00
Just got my newly purchased 420B (gas motor/converter drive) running well and discovered ATF leaking out of the starter. Is there a seal in the starter or is this indicating a bigger problem?
Jim B
09-22-2004 18:54:30
 Re: 420B starter leaking ATF in reply to Bill G, 09-22-2004 10:47:00
All Case tractors I've seen with torque converter drive have the flywheel and therefore the starter drive unit exposed to the torque tube oil supply, which is sometimes ATF. Yes, the starter has a seal. I've had to repaired mine on an 800 & a 830 with COM and a 580CK.
