VAC Starter
RBF
09-22-2004 04:15:29
When I attempted to start my tractor yesterday, the starter sounded like it was spinning but the engine was not turning over. Best I can figure out, there is no contact with the flywheel.
I removed the starter and found what looks like a large spring on the starter broke. Could this be the problem? Any ideas??
Tractor is a 1948 Case VAC.
Thanks
David
Ross Brothers Farm
RBF
09-25-2004 17:41:01
 Re: VAC Starter in reply to RBF, 09-22-2004 04:15:29
Thanks guys.... the repair on the starter cost me $15.00 and everything is back to normal!
David
C. Amick
09-22-2004 13:58:41
You can get a new spring for around $20. You can also buy the whole rebuilt starter drive assembly with spring for around $30. If the teeth are worn, I would replace the whole drive assembly. I know that V a l u - b i l t Tractor Parts carries both the spring and the entire assembly. Any auto electric shop should be able to order them.
F-I-T
09-22-2004 06:30:27
David:
Yes I believe that is your problem. If you look closely, there is a hook on each end and this sprint allows the driven gear to give and absorb shock. Without it, there is no connection between the starter motor and the gear, so the gear is free to spin, or likewise, the motor is free to spin and the gear standa still. It shold still be available from Case or even a decent Automotive starter rebuilding shop.
Frank
