Case 485 tie rod end misalignment
A Howes
09-21-2004 18:10:34
I went to replace the outer tie rod end and when I line the adjustment divots in the rod with the adjustment-holding bolt, the pin does not line up with the hole.
I will look at it more tomorrow morning, but thought I'd ask for guidance in case it is as it appeared earlier today. How do you get the set bolt to fit properly into the divots and still have the end pin/bolt fit into the hole?
Sorry for the non-technical lingo here, I'm just a play farmer... Thanks in advance.
