engine question
INCase
09-21-2004 14:02:45
I have a 730 gas (1961) that has been sitting for about 10+/- years. I have pulled the heads and started to clean up the rocker arm assemblies. THe rocker-arm shaft(s) is pretty rusty from years of sitting with condensate inside the engine. (I've pulled the pan a while ago but don't remember what it looked like). Question: will I likely have trouble with the rest of the internals on the lower end of the engine too? ALso goofed up trying to tap the shaft out of one of the rockerarms and pushed in the end plug. are there replacements for those???? THANKS VERY MUCH IN advance for the help!!!! any other advice?????
george md
09-22-2004 18:19:07
 Re: engine question in reply to INCase, 09-21-2004 14:02:45
INcase,
The book says drive the plug all the way
thru and out the other end to clean the shaft.
If you don't find a plug holler , I have a box of
almost every size.
george
INCase
09-24-2004 05:26:18
 Re: engine question in reply to george md, 09-22-2004 18:19:07
What book do you have? where are you at? I will probably need 4 plugs... thanks
