SC Rock Shaft Leaks
Glenn FitzGeral
09-20-2004 20:27:17
The right rock shaft on my SC leaks gear lube. I believe I read on this post that this leaking is stopped by keeping the rock shaft greased. Our 730 had grease fittings on each side but the SC does not. How do I stop this leak? Thanks, Glenn
todd hamilton
09-21-2004 15:17:46
 Re: SC Rock Shaft Leaks in reply to Glenn FitzGerald, 09-20-2004 20:27:17
Hi Glenn - I don't have an Eagle hitch so I had to look up exactly what a rock shaft is on an SC. The service manual has a good exploded view of the assembly. There is one O ring on each side between the bushing and the spacer. Sounds like the O rings are dried out. I see no grease fittings in this picture.
Glenn F.
09-21-2004 15:43:04
 Re: SC Rock Shaft Leaks in reply to todd hamilton, 09-21-2004 15:17:46
Thank you Todd. Are you set up to post a picture of that diagram? Thanks, Glenn F.
Glenn F.
09-21-2004 16:24:42
 Re: SC Rock Shaft Leaks in reply to Glenn F., 09-21-2004 15:43:04
If all things in life were so simple! I went out to the shop and had the arm/shaft apart in 5-10 minutes. Have the o-ring on my desk now. It does look worn flat. Thanks anyway. Glenn F.
