Case 580B
Richard Amaral
08-14-1999 21:21:57
A friend has a Case 580B tractor equipped with a front end loader and backhoe. The year is probably early '70s. The tractor runs fine from a cold start for about two or more hours, than the transmission begins to slip going forward only. Reverse is fine. Stopping the tractor for about 20 to 30 minutes corrects the problem for about an hour or two more of work, than it happens again. The problem occurs in hot or cold weather. Any help would be appreciated.
-Rich
Bob
08-16-1999 20:34:36
 Re: Case 580B in reply to Richard Amaral, 08-14-1999 21:21:57
I am assuming that your friend's tractor has the power shuttle not the mechanical (clutch) shuttle. His forward clutch pack is failing. I am a little surprised that it runs as long as it does before it begins to slip. All that can be done is to replace the clutch pack. Not a fun job, the tractor has to be split. Good luck!
