SC Oil pump...Adjustable?
Glenn FitzGeral
09-19-2004 19:19:04
I took my SC apart this afternoon. It needs a set of piston rings. My oil pressure runs about 22 lbs. when engine is warm which isn't too bad, but can that pump be adjusted to increase the pressure a little? It seems I've read on this board in the past that it cannot be but I don't see it in the archives. The screen on the snorkle looks clean. Thanks, Glenn F.
george md
09-20-2004 21:11:47
 Re: SC Oil pump...Adjustable? in reply to Glenn FitzGerald, 09-19-2004 19:19:04
Glenn, Usually when the pressure is low , it is
caused by either worn gears in the pump or worn
housing -or both - or too much bearing clearance.
In either case the pump is not making enough flow
and setting the relief higher will do no good as
it is not making enough press to open it now.
george
C. Amick
09-20-2004 14:21:28
I vote, No. I'm not 100% sure though. I've had several of them off, but never tried to increase the output.
Glenn F.
09-20-2004 19:57:54
 Re: SC Oil pump...Adjustable? in reply to C. Amick, 09-20-2004 14:21:28
I looked at the pump today and that is my vote also. There is a pressure relief valve but no adjustment that I can see. Thanks Ar. Amick!
RobertTX
09-21-2004 06:29:31
 Re: SC Oil pump...Adjustable? in reply to Glenn F., 09-20-2004 19:57:54
Usually you can shim the spring to get more pressure. Like the other guy said, if the pump won't make the pressure, it will not help, but usually the ball wears a little and the spring weakens. Try putting one or two flat washers under the spring.
