convert 1270 case to 540 pto
Ryan Hutchison
09-18-2004 20:51:10
does anybody know if you can change the gears in the rear end of a 1270 and convet it to a 540 pto? could you take the back-end from a 2290 and put it on a 1270 and the have dual pto 540/1000?
just wondering if anybody has some knowledge, trying to run a baler with 1270 and the baler has a 540 pto on it.
thanks in advance.
kycase
09-20-2004 09:15:35
 Re: convert 1270 case to 540 pto in reply to Ryan Hutchison, 09-18-2004 20:51:10
On some balers (dont know about all) you can swap the gears on the input and output shafts of the baler gearbox and change it from a 540 to a 1000 RPM PTO. My dad did this on a 535 JD and it works fine.
Grumpy
09-19-2004 21:52:41
There are no gears made to change 1270 1370 or 1570 to 540 PTO. 2290 is completly different rear end. Stan
Ryan Hutchison
09-23-2004 19:52:22
 Re: convert 1270 case to 540 pto in reply to Grumpy, 09-19-2004 21:52:41
Thanks for the information. as for changing the gearbox around on the baler, i have a JD 582 silage baler with pre-cutter on it and the gear box has an input shaft and two output shafts, on eon each end so flipping it around would be difficult, but thanks for the input.
