CASE 430 D
steve-TENNESSEE
09-18-2004 20:09:33
LEAK AROUND WATER PUMP-PULLED PUMP,IT LOOKS GOOD,CUT OUT A GASKET AND USED SEALANT.CRANKED IT BACK DOWN,BUT IT STILL LEAKS AROUND BASE/BOTTOM OF CASTING.
ANY SUGGESTIONS
THANKS
Roger (Mi)
09-22-2004 21:25:11
 Re: Case 188 diesel? in reply to steve-TENNESSEE, 09-18-2004 20:09:33
There is a gasket between the water pump housing and the block, but that's NOT your problem unless it's leaking between the block and water pump/timing gear housing. Rather, the seal in the water pump is defective. Replace the water pump. Rebuilt water pumps are reasonable in price.
steve tennessee
09-23-2004 06:49:47
 Re: Case 188 diesel? in reply to Roger (Mi), 09-22-2004 21:25:11
thanks
Tom (Ks)
09-19-2004 11:22:35
 Re: CASE 430 D in reply to steve-TENNESSEE, 09-18-2004 20:09:33
If you have a timing cover with seperate water pump, there is a o ring or packing between the pump and timing cover.
steve-TENNESSEE
09-20-2004 07:16:39
 Re: CASE 430 D in reply to Tom (Ks), 09-19-2004 11:22:35
thanks ,i will pull it and look at it.
