 Hi KC: You have to remove the cable from the battery post and then connect the lamp in series with one lead of the lamp hooked to the loose battery cable end, and the other lamp lead hooked to the battery post. I drew up a very crude diagram that might help. Out of habit, I always unhook the ground cable, because it generally is only one conductor, as opposed to the hot cable which can have a large cable to the starter, and one or two others that supply the main voltage to the instrument panel and lights (like on most cars). The thing is that if current is flowing, you can detect it by using the light bulb like an ammeter. Any current flows from the battery to ground, the lamp will light. Now, if it's a BIG short, you might also pop the light, because it's be a fuse! Ha! Let me know if you have any problems. It's a great trick and will save you hours of guessing. Frank-in-Tallahassee 70D // 855 // VAC // IHC �Cub� [email protected]
