Question about 207 diesel piston kit
David in SC
09-18-2004 03:31:04
Hello,
I have a 207 diesel in a 450B loader that desperately needs a piston/sleeve kit. Problem is, the engine serial number is missing and there are apparetly 2 kits available. I can not tell by the manual that there is any difference in the 2 kits as far as the pistons/sleeves go. I have found someone that has a sleeve/piston kit for sale never opened. I might can get for a reasonable price. I assume pistons/sleeves is the majority of the $700 cost of the rebuild kit? If I can get this reasonably, then I buy the other parts and maybe come out ahead a little.
This kit is for the newer model 207 diesels, which I may or may not have. Does anyone know if this will fit both versions of the 207 diesel?
Thanks in advance.
David in SC
Luke 10:27
09-18-2004 14:25:41
 Re: Question about 207 diesel piston kit in reply to David in SC, 09-18-2004 03:31:04
David,
The 450B had the late s/n 207. You will be fine with sleeve kits that you have found unless your engine is factory turbocharged. If it is keep looking, you�ll probably end up at a dealer.
Marc
David inSC
09-20-2004 03:11:07
 Re: Question about 207 diesel piston kit in reply to Luke 10:27, 09-18-2004 14:25:41
Thank you very much Luke 10:27.
David in SC
