unknown tractor
flbaggett
09-17-2004 19:11:41
MY BUDDY, WHICH IN NOT IN THE COMPUTER AGE JUST BOUGHT A TRACTOR WHICH WE GOT RUNNING.WE KNOW IT IS A CASE BUT WE DON'T KNOW WHAT KIND. THE TAG IS MISSING. THE NUMBER ON THE BACK OF THE BLOCK IS 23E06435. ALL OVER THE TRACTOR ARE CASTING NUMBERS THAT START WITH VT. THE BLOCK HAS A CASTING NUMBER OF VT-328. ALL THE OTHER PARTS HAS THE SAME VT NUMBERS. PLEASE HELP! WE ARE NOT CASE SMART. THANKS IN ADVANCE.
Alberta Mike
09-18-2004 06:16:16
 Re: unknown tractor in reply to flbaggett, 09-17-2004 19:11:41
The V series also had VT letters in the casting numbers. If you tractor is an overhead valve, then it is most likely a VA series (or one of the numerous VA models) of that series.
Joe (Wa)
09-17-2004 22:30:10
The VT casing nrs were used on the VA series, the most common model being the VAC but could be VAO, VAI, VAH, VAS. Check your engine serial nr again, the first digit probably is a 7 vice a 2. The 73E engine is ballpark 1953-55.
Check the Tractor Photos in the Galleries section on you left here.
Joe
