LA crank hub take off
mike's600
09-16-2004 18:30:54
How do i get that hub off after i take out the set bolt?
Thanks mike
RobertTX
09-17-2004 07:26:28
 Re: LA crank hub take off in reply to mike's600, 09-16-2004 18:30:54
Use a puller, grab it around the hub, not the pulley. Tapping can help, but be very careful, I broke one.
Screamin DC
09-17-2004 11:51:21
 Re: LA crank hub take off in reply to RobertTX, 09-17-2004 07:26:28
Ya i broke one tryin to knock it off. The best way is to put the puller on, tighten it and give the pulley a shot of penetrating oil. Let her sit for a few hours or even a day, go back and check if its loose. If not tighten it some more and use more penetrating oil. it will work its way loose.
