Case 800 Diesel - Is it worth fixing???
Neal
09-16-2004 15:42:04
Well tonight was not a good evening. I started my 800 and threw a rod out the side of the block. Now I am wondering if it will be worth tearing apart and finding another block. The things that I have read here on the discussion board that these tractors usually have wrong with them, this one seems to be ok.
Any thoughts as to whether I should fix it or should I think about parting it out? I just hate to dissmantle for parts.....
Bob/wis
09-18-2004 04:41:40
 Re: Case 800 Diesel - Is it worth fixing??? in reply to Neal, 09-16-2004 15:42:04
Neal,
Where are you located? I have a 800 here in wisconsin that had bad heads that I am parting out. It ran but puked water all over the place. Later Bob/wis
davud
09-17-2004 15:50:17
neal, I have an 800 I am parting out
Pat T
09-16-2004 16:58:02
If the only thing wrong was this, and I really liked the tractor, I think I would try to find another short block or engine. One from a 400-700 or early 730 will work (might need the heads if you use a 730 engine). Other side of the coin is you can probably make money on the tractor parting it out if the COM is good and you have all the rest of the parts, especially sheet metal, fenders, eagle hitch parts. Probably didn't help much, did I?
Neal
09-17-2004 05:14:05
 Re: Case 800 Diesel - Is it worth fixing??? in reply to Pat T, 09-16-2004 16:58:02
Thanks. Atleast if I decide to fix it up I know what tractors to look for on a short block.
Tim in NY
09-17-2004 09:52:34
 Re: Case 800 Diesel - Is it worth fixing??? in reply to Neal, 09-17-2004 05:14:05
Neal,
I'm just starting to restore a 700. I need the usuals - grilles, fenders, seat. Let me know if you do decide to part this out. Hope you decide to fix it though!
Tim in NY
