VAC Eagle Hitch
Jay P
09-16-2004 07:39:33
I have juse aquired a VAC with a Eagle Hitch, my question is where do you check and or fill the hydraulic oil. Any help would be appreciated.
Joe (Wa)
09-16-2004 11:29:37
 Re: VAC Eagle Hitch in reply to Jay P, 09-16-2004 07:39:33
The torque is the hyd oil reservoir. Follow the clutch linkage rod forward from the foot pedal until you see a small 4 bolt flange (on later VAC clutch rod pivot is on this flange) on the side of the torque tube. There is a 3/4 npt pipe plug above the flange. Oil level is to the lip of the plug opening. Holds about 2 gal. The oil return filter is in the tube under the 4 bolt flange.
Joe
DCTOM
09-16-2004 09:57:41
TOURQUE TUBE
