VAC Marvel Carb Problem
Eric Foster
09-15-2004 12:25:47
I have a small problem (I think). The tractor runs fine, but takes a while to start the first time. It takes several cranks and finally spits and sputters black smoke like it's flooded. Once it's started, I can turn it off and it restarts very easily. When it's not running, I see gas leaking from the air intake (between the carb and oil bath).
I'm thinking either the float is stuck open, the float level needs adjusted or the fuel intake needle is not seated. Is there anything else I'm missing? Please respond to [email protected].
Thanks,
Eric
Jerry W
09-15-2004 12:46:24
 Re: VAC Marvel Carb Problem in reply to Eric Foster, 09-15-2004 12:25:47
Sounds like like your float is wrong (stuck or leaking) or your needle and seat are leaking. Your oil probably smeels gassy.
Jerry
