I was wondering how much a 1950 Dc weighs?
Nicholaus Sowde
09-14-2004 15:32:16
I was wondering how much a 1950 Dc weighs? I found the weight on the Dc in a D series service manual which says it weighs 4796 lbs with 12-38 tires. I was wondering if that weight counts the 75 lb cast front wheels that equal 150 lbs. It has calcium in the rear tires 12.4-38. It has one 150 lb weight on each rear wheel. Thanks
Russ
09-15-2004 15:18:41
 Re: I was wondering how much a 1950 Dc weighs? in reply to Nicholaus Sowder, 09-14-2004 15:32:16
How much does a hen way (1950DC); AAAAA AAAAA AAAA
Basic tractor 4600 AAAAA AAAAA AAAAA AAAAA A
12.4 X 38 w/CaCl 948 AAAAA AAAAA AAAAA AAAAA A
Rear weights 300 AAAAA AAAAA AAAAA AAAAA A
Front weights 150 AAAAA AAAAA AAAAA AAAAA A
AAAAA AAAAA AAAAA AAAAA AAAAA AAAAA AAAAA AAAAA AA
Total weight 5998 AAAAA AAAAA AAAAA AAAAA A
Add for fuel, oil & rider(s) AAAAA AAAAA AAAAA AAA
todd hamilton
09-15-2004 14:45:47
Case algebra states that DC=12 henweighs and SC=10 henweighs. The formula is based on the number of chickens you can roost on the steering drag link!:^)
Experience
09-15-2004 12:21:58
Enough to give it the bst traction of any 40+ hp tractor!
Case1950
09-14-2004 17:59:37
My DC with cast front wheels, set of rear wheel weights, fenders, 1/2 tank of gas and me (185 lbs) weighs 5780 lbs. No fluid in the tires.
Case1950
Glenn FitzGerald
09-14-2004 16:33:09
Those cast iron front wheels weigh more than 75 lbs. apiece.
mike's600
09-14-2004 15:45:47
My DC with press steel wheels weighs 5000 Lbs
