Case DI Small parts needed.
Joseph Gatton
09-14-2004 11:44:18
It's the small tings that can kill a project. I need the following parts for a 1951 Case DI ser # 519672DI.
Need 1 valve spring (Case Part # 0844 AB2).
Need 1 push rod (Case Part # 0-1770AB).
Need 1 choke shaft for Zenith 04990AB carburetor, outline #0-8964 (Case Part # C108-37).
If you have / or know where I can get any or all of these parts please let me know.
Thanks
Joe Gatton
Joseph Gatton
09-22-2004 10:42:32
 Re: Case DI Small parts needed. in reply to Joseph Gatton, 09-14-2004 11:44:18
I found the needed engine parts and more at Otto Gas Engine Works.
(http://www.dol.net/~dave.reed/otto.html) The choke shaft I had to make.
caseman-d
09-14-2004 20:16:19
Valve spring new # A21690
push rod new # A26592
carb lever new # B1391
Where you located at, I probably have a used push rod and a valve spring.
caseman-d
Joseph Gatton
09-16-2004 03:48:06
 Re: Case DI Small parts needed. in reply to caseman-d, 09-14-2004 20:16:19
I am located in Maryland, about 80 miles SE of Washington DC.
Contact info:
[email protected]
301/866-4071 day
301/872-4447 eve / weekend
Thanks
Joe Gatton
