Mystery in a VA aircleaner ??
Alberta Mike
09-14-2004 06:29:45
I was fixing up a VA aircleaner for a friend of mine and when I took off the bottom (removeable) oil cup I noticed a round tin plate in there with some slots in it, plus sort of a spring-loaded tab (2 springs) near the middle of that plate. I guess the tin plate is to keep the oil from splashing (I think) and funnel dirt down lower for it to be trapped but maybe not. Is it removeable (seems stuck or spot welded in)? And what is that tab/spring setup on top of the plate for?
Ron in mid MO
09-14-2004 15:20:09
 Re: Mystery in a VA aircleaner ?? in reply to Alberta Mike, 09-14-2004 06:29:45
Just got mine running so I"m new to this also. The parts catalog calls it a baffle and on mine the springs help hold the pre-filter up to the air cleaner. The pre-filter comes out also. Hopes this helps.
Joe (Wa)
09-14-2004 15:05:04
Some of the later air cleaners after engine serial nr A4700000 had a pre-filter between the oil cup and air cleaner chamber. The spring loaded baffle holds the pre-filter in place.
Joe
