Question for DCTOM
Tim Wilson
09-13-2004 08:32:34
I bought tractor # C335942 over 20 years ago, but have always questioned it's originality, according to the tag on the tool box it's a 1936 CC, but it has C rear wheels and a wide front end without the CC-4 spacer. If someone changed the toolbox, it was done many years ago as the tractor was uniformly bad when I bought it. Can you help?
Thanks,
Tim Wilson
Brian in Ohio
09-13-2004 14:35:59
 Re: Question for DCTOM in reply to Tim Wilson, 09-13-2004 08:32:34
What does the serial number stamped on the block say? It would be stamped on the mag side of the block, on a machined spot, near the fuel tank and just where the block and head meet. See if that number matches the number on the toolbox.
DCTOM
09-13-2004 09:39:34
TIM; ARE THE REAR WHEELS 26 INCH? IF THEY ARE IT IS A C IF THEY ARE 36 IT IS A CC WITH THE FRONT AXLE CHANGED OR ELSE THE NUMBER IS WRONG(TOOL BOX CHANGED) I HAVE NO CARDS FOR THE 6 DIGIT NUMBERS TOM
Tim Wilson
09-14-2004 10:34:17
 Re: Question for DCTOM in reply to DCTOM, 09-13-2004 09:39:34
DCTOM and Brian,
Thanks for responses, I should have mentioned in my post that my Case is on full steel with 42 inch rears and 28 inch fronts. Also there are no stampings of any kind on the machined surface of the block where Brian had mentioned. I also forgot to say that it has CC rear fenders. All of these things were as I found them 20 years ago when I found the tractor rusted up in a field in central Iowa. I can"t help but wonder if this tractor was involved in some type of mishap many years ago and the toolbox, fenders, and block were changed to make it useable. Thanks again for your time.
