G148 cranshaft in a Vac???
Jim McVay
09-13-2004 07:07:25
I'm rebuilding a Vac and trying to put G148 parts
in the engine that I was told would drop right in.
Sleeves are ok but the crank won't go. I seems the rear main bearing is either too wide on a Vac or closer to center main than on a G148. What can I do to make this work. Should I grind on the crank or on the block or both? Please HELP
mike's600
09-14-2004 15:48:14
 Re: G148 cranshaft in a Vac??? in reply to Jim McVay, 09-13-2004 07:07:25
You need a 148 Block. I have a 148 short block if you need it.
