LA Case beaten by John Deere
Walter
09-12-2004 20:33:56
I hate to admit it but at this weeks pull I was beat by an extremely hard pulling john deere 630 and a 730, I did beat a 720. I lost by 20 feet but still its hard to swollow. The old john deere was grunting and straining but it was making extremely good traction. I've tuned the LA up and it has LOTS of power ,never even got in a bind, but I can't keep the front end on the ground and just can't seem to get the bite I need for traction. I have new 18.4*30 titan tires, I've shortened the drawbar to up against the swing rail,I've raised the drawbar to 20". I'm running in a 7000-8000# & 8000-9000# class. Got spoke wheels on the front and 1000# of rear wheel weights. I know its all about balance. Any tips to make an LA bite the ground hard. Tried pulling at 18" height and thats worse, less traction, better on raring up. Put 200# on the crank handle and that helped a lot but I still came off the ground. I guess what I need to know is what ratio of weight should I rob off the back and put on the front before I start to reduce traction and wear do I need to hang it. Which is worse for pulling, lower rear wheel weight or raring up? Yes the john deeres had about 500# hanging on the front and about 500 on the back. Also this is "stock" pulls but drawbars don't have to be stock and weights don't have to be stock. We just can't allow this to keep happening. Help!
Josh Wilhelm
09-14-2004 16:59:29
 Re: LA Case beaten by John Deere in reply to Walter , 09-12-2004 20:33:56
Walter hey if you dont mind sharing a few secrets i am thinking of building an L Case. What do people do to make horsepower. Just keep playing with your weight ratio balance is a key thing. Try things and record what works and what doesn't so you know what to do on different tracs for how to balance your tractor.
Augie
09-13-2004 16:45:53
When the front comes up, the hitch point drops and you lose leverage against the sled pan. The ratio of front/rear static weight will vary based on hitch height, hitch length, wheelbase, tire size/width and a whole bunch of other stuff that you can't measure.
The goal is to get close and then fine-tune from there. If your rules allow your hitch point to be closer to the rear axle than where you are now - shorten the drawbar - that will help a bunch. If you can't make the hitch closer to the axle it's going to take more weight up front to keep it down.
Jim M
09-13-2004 06:40:23
Walter: Send me a e-mail at [email protected]
I'll give you some tips but don't want others that might protest what I tell you. Jim
