LA propane
Engineer20
09-12-2004 19:23:24
What year did Case first offer propane for the LA as an option? I've recently read a book that says 1952. I've also read on the fourm that it was 1949. What's the answer? My 1950 LA is propane powered. Could it be a conversion?
Thanks for you help!
DCTOM
09-13-2004 07:00:07
 Re: LA propane in reply to Engineer20, 09-12-2004 19:23:24
52 IS CORRECT FOR FACTORY LP BUT ANY LA CAN BE RETROFITTED WITH THE SAME LP GAS EQUIPMENT INCLUDING THE HEAD TOM
RobertTX
09-12-2004 20:13:35
I think your dates may be correct - 52 for the factory LP, sometime earlier for the conversion. One way that may be an indicator - I have been told that the factory LP head was a 6xxx number, the conversion is the 5xxx. I do not know if this is correct, but I have seen tractors that follow this pattern. If you find a source for Ensign parts, pleas pass it on. If you need some parts, I have some extras. My email is blocked, just post if you want to communicate off site.
