What Size LA Rear Tires?
TMAC
08-13-1999 21:05:38
I have a '49 Case LA with bad tires all around. The rear rubber is 18.4-30. Is this the correct size or are there other options?
Don R
08-17-1999 10:24:41
 Re: What Size LA Rear Tires? in reply to TMAC, 08-13-1999 21:05:38
LA Cases came with 15-30's which would now be 16.9-30 so you have wider than original tires. If
you decide to pull your LA keep the 18.4-30's. Cases always need bigger rubber than they came with from the factory.
Shaun in Wisconsin
08-13-1999 23:06:50
Click the Icon below
TMAC
08-16-1999 20:09:26
 Re: Re: What Size LA Rear Tires? in reply to Shaun in Wisconsin, 08-13-1999 23:06:50
I tried TRACTOR TIPS; it didn't follow through.
