German Bosch inline pump
Jaker
09-11-2004 16:59:27
I just purchased an 801 b case-o-matic. The tractor shows 2600 original hours. Every gauge in the instrument cluster works. I mean everything. The tractor starts and runs good with the exception of one problem. While running the overflow tube on the fuel pump drips oil. When the rpms are increased the drip becomes faster. The overflow that I am talking about is the copper line that runs along side the engine. On the 830 deisel that I have this line is plugged into the oil galley plug on the side of the block. Do I have a seal bad or is there something esle wrong with the pump. I can't imagine anthing to much being wrong as it starts and runs well except for the drip. Thanks Jake
Brent Behner
09-12-2004 07:43:46
 Re: German Bosch inline pump in reply to Jaker, 09-11-2004 16:59:27
Jaker That Pump Is Not PRESSURE FEED FROM ENGINE. When Changing Engine Oil You Are Suppose To Drain Injection Pump Oil. Drain Plugs At Bottom Rear, Filler Is On Top Of Pump At Breather Which Unscrews, Engine Oil 30 Weight, Fill Until Oil Runs Out Of That Tube. Now Having Said All This, Your Problem Is Seals Leaking Inside Pump Forcing Diesel Fuel Inside Pump Crank Case. BRENT Behner
