Case VAC-14 steering drag link
Steve Crum
09-11-2004 15:54:41
My neighbor has a late 1956 Case VAC-14 tractor (says so on the S/N plate) that he believes is a half breed VAC/300. He's trying to locate a replacement for his steering drag link, this is a wide front tractor and this drag link is the connection between the main pitman arm and the pitman arm on the right hand wheel spindle. the shank of it is 17 1/2" long to the center of the tie rod end on it, and the shank is notched for lengthening of the adjustable wide front.
Anybody have an idea of the part number? I can send pictures of the part if needed.
Thanks
Bill Hires
09-12-2004 05:39:12
 Re: Case VAC-14 steering drag link in reply to Steve Crum, 09-11-2004 15:54:41
VAC-13 and VAC-14 Parts numbers. VTA3155-tie rod notched drag link 52"-76" tread in front of axle.VTA3157-tie rod notched 52"-57" tread behind the axle. VTA3263 tie rod notched drag link 48"-68" tread in front of axle. VTA3265-tie rod notched 48"-68" tread behind axle.
Steve Crum
09-12-2004 05:57:46
 Re: Case VAC-14 steering drag link in reply to Bill Hires, 09-12-2004 05:39:12
Thanks for your help, I'll give Jim this info.
