help - davis trencher-backhoe problem
Therise Bond
09-11-2004 10:44:32
MY HUSBAND HAS A DAVIS -TRENCHER/BACKHOE. HE IS HAVING A TERRIBLE TIME REMOVING THE PIN WHERE THE MACHINE ARTICULATES. HE HAS TRIED EVERTHING TO REMOVE AND IS NOW TO THE POINT OF USING A CUTTING TORCH TO PERMENANTLY REMOVE. VERY FRUSTURATED, ANY SUGGESTIONS ON HOW TO GET THE DANG THING OUT BEFORE WE BOTH GO NUTS? ANY SUGGESTIONS WOULD BE APPRECIATED. THANKS
Dale(MO)
09-12-2004 13:30:43
 Re: help - davis trencher-backhoe problem in reply to Therise Bond , 09-11-2004 10:44:32
Therise,
I am not very familiar with the Davis machines (mostly Ditch Witch and Vermeer in my area), but the pin more than likely has a lot of wear at the bushings, so it has steps cut in it. Getting it all lined up so it will slide out is 'nigh on to impossible. I would probably cut the ends off with a torch, then slide the two halves apart, and knock the pieces out with a hammer. Can you separate the hinge journals enough to cut the pin? I would try not to get into these journals with the torch, as they may run thrust washers between them, and the torch marks will need to be taken out so as not to eat up the washers. I know by cutting you will have to get a new hinge pin, but if it can't be easily removed it probably has enough wear that it (and the bushings) need to be replaced anyway. The torch is usually my last resort, but sometimes it becomes necessary. Good luck, and keep us posted!
Dozerboss
09-12-2004 22:48:05
 Re: help - davis trencher-backhoe problem in reply to Dale(MO), 09-12-2004 13:30:43
Can't help, have been trying to get a service manual for a case davis 70+4 model. Case no longer sells it. Compared to JD parts the local Case dealer is mostly interested in the rental business and stocks nothing for older machines. JD even has their parts and illustrations online. I understand your frustration, you won't find anything on the net for parts for Case either. Hopefully the suggested method will work. I like the machine but parts availability is something to consider when buying Case. The Gas co uses them and wear at the center pin is the determining factor in when they sell them. If it has worn the bushings thru and egged out the bore, it's an expensive machine shop repair to fix it right. If i find a manual i will post the removal procedure.
Dennis/Ohio
09-12-2004 04:34:41
Post your question on Crawler, Dozer & Backhoe forum too. Sometimes that works better for me.
Best Dennis....
