Case Vac-14 starter trouble
V.VanSickle
09-10-2004 07:31:29
I recently got my Vac started after it had sat idle for over 10 years. It had always turned over very slow so I took the front of the starter off to look at the brushes. They were cupped and wore badly so I ground them down to flatten them outand put it back together and all it would do was spin and not engage the flywheel.I then took it to Napa and had it rebuilt but it still does the same thing. It appears that it is turning the wrong way and the bendix is not kicking the right way. Is this possible and if so how do i fix it.
Jerry W
09-10-2004 10:38:15
 Re: Case Vac-14 starter trouble in reply to V.VanSickle, 09-10-2004 07:31:29
You assembled it wrong. Take it apart and give the housing a partial turn and put it back together.
Jerry
V VanSickle
09-16-2004 12:13:08
 Re: Case Vac-14 starter trouble in reply to Jerry W, 09-10-2004 10:38:15
Great advice Jerry I called the machinist at Napa where the starter was being worked on and told him what you had told me and now it turns over like a new one. thanks a million.
